Fatal Error - Live Client Site down!
Thread began 12/10/2012 10:33 am by robert329616 | Last modified 12/10/2012 10:41 am by robert329616 | 831 views | 2 replies |
robert329616
I made a change to a file in the plugins/catalog folder and did not like the results. I copied the file from my backup and received a fatal error. I then decided to copy the whole catalog folder replacing the existing one. The fatal error went away but was replaced with the following:
Fatal error: require() [function.require]: Failed opening required 'searchbox.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/18/8451718/html/webassist/themes/Martab/plugins/plugins.php on line 10
Hopefully you can help since their site which is an ecommerce site is down right now.
I am using the latest powerstore.
Thanks!
robert329616
OK, Thanks for the quick reply!
