CSS Form Builder - label positioned above field
What is the setting in CSS Form Builder to position a field label ABOVE the field, not to the LEFT? So many different settings in the wizard to keep track.
In the Design Editor, select Form Elements from the main dropdown list, the Element Labels from the secondary list. Here you can control the settings for the Labels on the form.
