Can I turn off the compression of images in PowerStore
Thread began 12/06/2012 11:32 am by tim299030 | Last modified 12/06/2012 4:53 pm by Jason Byrnes | 737 views | 7 replies |
tim299030
I uploaded all of my images via ftp to the imagesupload directory and imported all my records directly through mysql. All the images show up fine but on the detail pages (product_detail.php) the images are of much less quality that what I uploaded.
Is there a way to turn off the compression so that the images that I uploaded are the same quality as what I originally uploaded?
Thanks in advance for the help.
in the webassist/caching/CachedResize_Image.php file, try changing line 207:
$process = $image_save_func($image_c, $save_path);
$process = $image_save_func($image_c, $save_path, 100);
tim299030
Thank you, Jason. It worked. Two questions, though:
1) If I've already viewed a page with the image being reduced quality will it view it as the reduced quality? In other words, if it's been viewed once the old way does it need to be recached?
2) Does that work for the thumbnails as well or do I need to change the code somewhere else?
Tim
1) Yes, if the image has already been cached once, it wont be recached unless you delete the cached copy
2) yes, thumbnails should work the same way.
tim299030
where are the cached images stored?
what code should I look for to change the thumbnails?
the cached images are stored in the webassist/plugins/catalog/scripts/image_cache/ folder
In what way do you want to change the thumbnails? Size? other? Thumbnails on the details page? other page?
tim299030
So should I delete everything inside of the image_cache folder?
I just want the thumbnails to be the same quality as the original uploads.
Thanks again.
yes, delete everything inside that folder to have the cached images regenerated. regenerating the cached images should fix the thumbnail quality too.
