Help in menu please
hello i make a desing and add my slices to my page using css but now i dont have any option to add link to my menu. any idea how do this
this is the site
actualidadcubana.com/
thanks
this is the site
thanks
since you are using 1 background image for the menu div, you will not be able to create links in the menu.
in the menu div, you should include a separate div for each menu item, then you can set the links and background image to the individual menu items.
ok but supposed this only image is the menu, how you add the link to this image??
thanks
you can add a link to an image by wrapping the image tag in an anchor tag:
<a href="page.php"><img src="image.jpg"></a>
yes but in this way put the image twice
because you are using one large image slice for the entire menu area. you need to break up the menu slices to the individual menu items.
you can use one large image slice for the menu navigation and add links, web page design does not work this way.
on the learning resources page:
tutorials-and-training/
you will find getting started kits for both CSS Designs and for CSS Menus, perhaps those will help point you in the right direction.
