Moved website now gets error sending files
Thread began 12/04/2012 6:30 pm by chris373619 | Last modified 12/05/2012 1:06 pm by chris373619 | 923 views | 6 replies |
chris373619
I just moved my ISP and now I get two errors on the upload page.
Page: send_file.php
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/69/10142169/html/send_file.php:37) in /home/content/69/10142169/html/WA_DigitalFilePro/HelperPHP.php on line 70
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/69/10142169/html/send_file.php:37) in /home/content/69/10142169/html/WA_DigitalFilePro/HelperPHP.php on line 70
Any idea what this is from?
The headers already sent error is caused by output between PHP tags. it could be a blank space, a blank line or HTML code.
this section of the error:
is telling you that the problem is caused around line 37 of the send_file.php file. look for a closing php tag at line 36 and any out put after it.
see this thread for more details on the cause of the headers already sent error and how to troubleshoot:
showthread.php?t=19285
chris373619
I looked at the link but couldn't find anything I could use to help.
I looked at the code on my "send_file.php" document. Below is the php code from line 37 to 71.
Line 37 has memory_limit code. Could that have changed due to the new server?
I'm wondering what version of php the new server has also. Should I have a specific
version of php installed?
Code:
<?php ini_set("memory_limit","250M"); ?>
<?php require_once("WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "upload/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "0", "", "false", $WA_UploadResult1_Params);
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
//Send Mail All Entries
$RecipientEmail = false;include("WA_Universal_Email/WAUE_index_1.php");
if (""!="") {
header("Location: ");
if you examine the link a little more carefully, one trick is to enable hidden elements which will show spaces.
the most likely culprit is a blank space after a closing php tag:
or a blank line between a closing php tag and the next opening tag:
<?php...
chris373619
I looked back at your link and read through the possible problems. I didn't see those issues in the code. Can you see if you see them?
send_file.php.zip
wellllll, the php code that is at lines 37 - 73:
if(isset(
$_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1""upload""0""""false",
$RecipientEmail false;include("WA_Universal_Email/WAUE_index_1.php");
  if (
header("Location:");
should be above the doctype tag at line 1.
by having that code inside the HTML, it is causing the headers already sent error
chris373619
That was it. I would have never figured that one out.
Thanks for your help!
