Bug? - pcms2_contents.ParentID
Hello,
Does this field work in the scheme of things?
If so in what context?
The reason for my question is that I am not seeing basic database keys linking content areas that have more than one Content Column
For instance to SELECT from another content area tied to a Parent there is no integer using the ContentID as the Primary Key.
While the different methods of rendering Content in PowerCMS work in a simple manner the Extension is a starting point for more elaborate CMS solutions and my question is if the UPDATE and MODIFY functions are incomplete since the ParentID field is not being used as a Foreign Key reference??
