DataBridge using old DataAssist Style - Traditional Pacifica
Thread began 12/03/2012 8:16 am by dlovas275157 | Last modified 12/04/2012 8:54 am by Jason Byrnes | 853 views | 1 replies |
dlovas275157
I have multiple sites with older DataAssist pages (results, search, insert, update, delete, detail). They were all generated with DataAssist 2.0.8. I used the Traditional Template with Pacifica styles.
I am now using DataBridge 1.0.9.
Problem: I would like all my backend cms pages to match, but the "Traditional-Pacifica" style is no longer available as an option in the new DataBridge. Is there a way I can still use it by moving files around in my config folder or DataBridge install folder?
Thanks for any help.
Daniel
There is not a similar design available in the Data Bridge wizards. you would need to select the basic design, then edit the CSS after the site has been created to use the colors from the older designs.
