Problem with Apostrophe in Data
I'm running into a brick wall trying to get an apostrophe to output to a URL parameter.
Inherited a database that used apostrophes in several brand names. Want to use those brand names as a URL parameter; I've tried all the escape tricks I know, but the apostrophe and following letter won't show.
Example:
The brand name in the db is Mickelberry's. If I try to escape the apostrophe with a '\', the '\' shows in the URL, and the 's' doesn't.
Suggestions??
Thanks,
Mike
ETA: Disregard -- fixed it by swapping single and double quotes in the code. DUH!!!
