admin not seeing css
The admin is not seeing the CSS, so it's not loading correctly. I tried to upload the admin folder again by it isn't working.
See attached jpeg.
See attached jpeg.
I have answered you job ticket, please let me know what else you need me to do
Hello,
I have the same problem, and don't know what to do
Do you have an idea?
this was a permisions error.
on trying to access the CSS in PowerMessenger/webassist/themes/Default/css/default_styles.css
i got the following error:
Forbidden
You don't have permission to access /PowerMessenger/webassist/themes/Default/css/default_styles.css on this server.
using file zilla i changed the permissions for the webassist folder and all files and folders under it to 755 to correct the problem
Thank you Jason, will do it next time
