Delete File Causes Errors :-(
Thread began 11/30/2012 6:21 am by Cologne | Last modified 11/30/2012 9:55 am by Jason Byrnes | 474 views | 4 replies |
Cologne
Seems to work when I use hidden fields.
Denis
Hi there,
may it be, that the DELETE FILE behavior is not working?
Warning: unlink(/www/htdocs/w1/unserWeihnachtsfenster/Upload) [function.unlink]: Permission denied in /www/htdocs/w1/unserWeihnachtsfenster/webassist/file_manipulation/helperphp.php on line 763
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/w1/unserWeihnachtsfenster/webassist/file_manipulation/helperphp.php:763) in /www/htdocs/w1/unserWeihnachtsfenster/members/images/delete.php on line 90
This is line 90 "header("Location: ".$WA_redirectURL);"
If these are errors I cause, let me know. It seem I work from error to error :-(
Help please :-)
Denis
delete.zip
the error is pretty strait forward, it says Permission denied, meaning that the server is not allowing the file to be deleted due to permissions on the server.
make sure that the folder and all files inside it where you are trying to use the delete file behavior have full access
Cologne
I did, and turned it as it was.
then I saw a thread in the forum to put the ID for the recodset and the imageName in a hidden field.
since i did that it works.
Cheers,
Denis
Cologne
is there a tutorial for using the Automatic Login?
I used the wizzard but I cant see it clear. 6 cookies a created.
Thsi works well
05_recall_login.swf
but how can I delete the remember login when I uncheck the box.
and how does it work that I login automatic? I need to trigger the button right?
Denis
no, there is not a tutorial for automatic login.
the basic idea is that you use the set cookie behavior to store the user name and password entered, triggered off whether the remember me button is checked
have another set cookie behavior to save an auto login cookie if the auto login box is checked.
you then add a second authenticate user behavior to the page that triggers if the auto login cookie is set and uses the username and password cookies.
use the wizard to generate the pages with the auto login feature enabled to inspect ow it gets created.
