Pass original querystring
I use the lastest version of data bridgue to create my administrative backend.
I create a results, update, and insert page. The pages edit the products table that contains an "category" field with a relation with the products table.
To do this, i config the results page to filter the results with an idcategory URL parameter. It works but i find this problems:
- Results page do not pass the idcategory parameter using GET. I solved this doing it manually, but is there any wat to do this with the wizard?
- I change the target page after update to results page directly. I check the "Pass original querystring" option, but it doent´s mantanis it, although the idcategory parameter is present in the URL.
Thanks and sorry for my poor English.
