Changing button colors
In which stylesheet can I change the background color of the buttons? Please see attached screen print. Thanks!
the buttons are images. you would need to edit the images to change the background color. the images should be in the /images/icons folder
I don't want to change the images, just the background color of the button. The images themselves are fine - I've already looked at them and they are already transparent PNGs. How do I change the background color? Thanks!
using Fire Fox with Fire bug, you can easily inspect elements on your page to find the CSS attributes that are controlling them, you can even edit the CSS to experiment in real time.
Through fire bug, it looks like the selector for the buttons is:
form .WADAResultsContainer input.formButton.ResultsPageButton
you can add a background-color attribute to change it.
