Date chosen in date picker shows as 12/31/1969
Thread began 11/29/2012 6:13 am by MikeyT | Last modified 11/29/2012 5:15 pm by MikeyT | 5083 views | 2 replies |
MikeyT
Hi Jason,
Bit of a problem here that I need to sort out. I have a back end CMS system built with Data Assist and Form Toolkit (pre-Data Bridge). On the Insert page is a date picker. When you choose a date it enters into the form field just fine, but when you click submit to commit to the new event, the Details page shows the date as 12/31/1969. You then have to go to the Update page and fix the date wither manually or click through forty odd years in the date picker. Then it sticks and continues to show correctly on the Details and Results pages.
I've included the source files hoping you can lend me a hand in sorting this out. If you need to see the problem live, I'll need to have a support ticket opened to do a screen sharing session since these pages are password protected. Thanks... appreciate the help.
Mike
sourceCode.zip
the data base expects the date to be in yyyy-mm-dd format.
add the following code at line 1 of the insert page to convert the date to the format expected by the MySQL database:
if($_SERVER['REQUEST_METHOD'] == "POST") {
    if(isset(
$_POST["pe_date"])) $_POST["pe_date"] = date("Y-m-d"strtotime($_POST["pe_date"]));
MikeyT
Thanks so much. Its working as expected now.
