Column header sort not working
Please see attached file. Can you tell me why the column header sort isn't working? Sorry ... it's in ColdFusion...
I don't receive any errors - it just doesn't sort. Thanks!
your sort link is passing a column name that does not exist "applicantLastName":
<a href="tblScholarshipsAwarded_Results.cfm?sort=tblApplicants.applicantLastName">
it should be "last_name"
<a href="tblScholarshipsAwarded_Results.cfm?sort=tblApplicants.last_name">
Jason, that still doesn't work, and the field dateAwarded doesn't sort either. No errors, it just doesn't work...??/
Jason, I just got it working. This piece of code was missing from the query:
#PreserveSingleQuotes(WADA_Sort_1.FinalOrderClause)#
I now used this code to replace the default sort order. Thanks!
ok, glad to hear it is working.
Thanks, Jason. You can cancel the support request.
Cool, will do.
(pheewee, dodged the CFM bullet.......)
Hahahaha! Yes, you did dodge that one :)
