an unidentifed error has occurred
Thread began 11/26/2012 3:39 pm by randyw2394710 | Last modified 11/28/2012 11:27 am by Jason Byrnes | 721 views | 3 replies |
randyw2394710
i have proper set up of data base and password username ive used data assist befor now i get this error when i test the connection
im using the powercms connection and my tables or data base does not show up ive unistalled orriginal datta assist and installed the most current 2.1.0
This error means that there is a problem with the site definition settings.
the error is specific to the settings for the connection to the testing server in your site definition.
Make sure that the URL PRefix is a proper web address to your site.
see the "Defining a Dynamic Site in Dreamweaver" tutorial on our learning resources page:
tutorials.php
randyw2394710
tutorials.php
the database connections are ok everything should work i still cannot get to database tables ive done this thousands of times befor nothing has changed i have db forge studio which is connected with same information and that works fine
How is the testing server section of the site definition defined?
are you connecting to a local or remote testing server
double check that the URL prefix is the correct URL to connect to the web server.
the error indicates that the Dreamweaver Site definition is not set up correctly.
