Data Bridge Subsciption Tutorial Preset: Import error
Thread began 11/26/2012 12:03 pm by Kevin.Allen | Last modified 4/11/2013 8:38 am by Jason Byrnes | 2635 views | 10 replies |
Kevin.Allen
Just downloaded the new Preset for the Tutorial for Subscribing/Unsubscribing users for a newsletter... very excited about it... and... when I went to import the file(s) I got an error saying that the file is
"not a valid Data Bridge Application preset".
Two files were included in the zipfile I downloaded from your site: wa.xml and newsletter.xml
I tried to import each of them, in turn, after getting an error on the first attempt.
each of these files return the same error.
Thanks,
Kevin Allen
Kevin.Allen
Addtional Info
Just realized I should have included this: I'm on Windows 7, running Dreamweaver CS6 and I have version 1.09 of Data Bridge installed.
make sure you select the option to save the zip file to your computer.
In the preset manager set the product Dropdown to Data Bridge - Preset. when you click the import button, browse to and select the data-bridge-newsletter-subscribe-unsubscribe.zip file that you downloaded
kevin_d_allen182238
Still getting error on loading preset
I have the preset manager set to "Data Bridge - Preset" and click on the INSERT button - and it generates this error:
"While executing onMouseDown in walm.htm the following JavaScript error(s) occurred:
in file "walm":
wa.page0 has no properties
------- it doesn't even let me begin to browse to the zip file I downloaded.
What is your OS?
What version of Data Bridge do you have installed?
What other extensions (including the version numbers) are installed?
What is your Dreamweaver version?
kevin_d_allen182238
  What is your OS?
Dreamweaver Version CS6 , version 12.1 build 5966
Extensions installed:
Design Extender ver 1.1.1
eCart ver 5.0.7
Data Bridge ver 1.1.3
PayPal eCommerce Toolkit Recipes ver 1.0.0
eCommerce Recipes ver 3.0.0
these 2 extensions have been replaced by free tools:
uninstall all of the Webassist extensions, and download free tools.
then install them in the following order:
eCart
Free Tools
Design Extender
Data Bridge.
kevin_d_allen182238
I'll give it a go.
kevin_d_allen182238
Presets loading correctly now - but one nagging error message left.
Thanks... that took care of the errors - was able to import the preset
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
