remove products navigation on Contact and Support pages
Thread began 11/26/2012 1:17 pm by turk361661 | Last modified 12/04/2012 12:44 pm by Jason Byrnes | 615 views | 3 replies |
turk361661
1. The Contact Us and Support pages both display the Product navigation on the left side of the page ? (this is the same product menu that appears on the Products landing page).
Can I replace the product navigation with something else on the Contact US and Support pages only?
2. On the Product Page, I would like the Side product menu to include the Search and Show All links?
Currently the "Search" and "Show All" links only display in the drop down menu in the main navigation. I would like these links to also show up in the product menu that displays on the left side of the product page.
How can I accomplish this?
Thanks for your help!
Danielle
1) on any page that you don't want to show the side menu add the following code at line 1:
<?php $blockSideMenu true?>
2) Adding links to the side menu is not supported. You would need to edit the sidemenu.php webassist/plugins/side_menu, side_menu/accordion and side_menu/nested_accordion folders.
turk361661
removing side menu and replace with image/text
Thanks for the help!
Regarding your response in #1.
Okay. I can hide the side menu on Contact page. That's great. Can I have something else display in it's place on the right (such as an image with some copy/text underneath). I can create the html/css for what I want to display but I'm not sure how to code in the PowerStore framework so it displays in correct spot.
Thanks again for your help!
Danielle
This is not a supported modification of power store, you would need to edit the template files to add the custom contents, and would need to code an if statement to only show on certain pages.
