Problem with adding "Add to Cart" button
Thread began 11/25/2012 7:16 pm by sjones435326 | Last modified 11/26/2012 5:35 pm by sjones435326 | 473 views | 4 replies |
sjones435326
Hello, I have went through the instructions several times. When I add the Dynamic "Add to Cart" button, and upload all of the files. I then get an Error - "HTTP Error 500 (Internal Server Error):" - after several attempts I have verified that if I comment out the code that is generated at Line #2 <?php //$Ripper_Owens_Tap_House->GetContent(); ?> Then the page will show up. Any idea of how I can fix this?
Thank You!
send a copy of the page please so i can see the full code in context.
sjones435326
Hello Jason, I have attached the file in the zip folder. Let me know if you need any other information. Thank you for your help.
SUPPORT-products_Results.zip
move the code at line 48 - 51:
//WA eCart Include
require_once("../WA_eCart/Ripper_Owens_Tap_House_PHP.php");
to line 1
sjones435326
Thank you Jason, That did the trick!
