Data Bridge - DataAssist Insert photo not uploading
Thread began 11/25/2012 2:08 pm by eric284736 | Last modified 11/26/2012 3:36 pm by eric284736 | 763 views | 5 replies |
eric284736
Hi Jason,
I ran the DataAssist Pages wizard and the upload files does not work.
The form insert all of the data but it does not upload the file or insert the file name into the database.
thx
Eric
items_insert.zip
i dont see a problem in the code.
To help troubleshoot, add the following code at line 1:
error_reporting
(E_ALL);
if(
$_SERVER["REQUEST_METHOD"] == "POST"){
var_dump($_FILES);
and report the results after trying to upload a new file
eric284736
Hi Jason,
I added the code and did a test, but no errors were displayed.
The file did not upload and the file name was not inserted into the database.
What next? :)
Thx
Eric
eric284736
Jason,
If I were to uninstall data bridge and reinstall would I loose the presets I have in place?
Also, do I need to install the extensions in a certain order? I did an update to Dreamweaver CS6 to build 12.1 - 5949 and maybe that is causing my issue. So maybe cleaning the slate and doing a reinstall of the extensions will help??
I have currently installed:
Data Bridge
eCart
CSS Sculptor
Free Tools
CSS Menu Writer
Social Media kit
thx
Eric
yes, you would loose the presets, open the preset manager (webassist -> Preset manager) and export them before uninstalling Data Bridge.
install order is not the cause of the problem, it is an error on the server. I will start an incident so i can get access to the pages to troubleshoot.
eric284736
Thanks Jason!
Do you want me to send FTP access on the support ticket?
thx
Eric
