css float problem
Thread begun 11/23/2012 8:17 am by CraigR | Last modified 11/24/2012 7:44 am by CraigR | 3754 views | 8 replies |
CraigRBeta Tester
css float problem
i have a page of product categories, where each category image sits in a left floated div, so that i can fit 3 to a line, giving a grid like effect.
i want some text to sit beneath each set of images, which varies depending on the number of items in each category.
where i have 3, 6 or 9 images, no problem, the grid is filled, the text sits underneath, however if I have 4 or 7 images, the text sits alongside.
i have tried adding a clearboth break below the 'grid', but this forces the text to below the content of the left sidebar.
eg category.php?CategoryID=1
looks ok
category.php?CategoryID=14 has a big gap because of the sidebar.
JamieEff
Have you tried wrapping the element above it in a div and then using clear:right; instead of both ?
Jamie
CraigRBeta Tester
Hi Jamie.
Yeah, i tried that, i put all the repeating elements within their own div, tried clearing right only, even put the text in a div with a fixed width and it still won't behave itself
MikeyT
I'm not sure if this is what you're tying to accomplish, but removing the { clear: left; } property on the id named #clearFloat removes the large gap.
CraigRBeta Tester
thanks for looking Mikey.
It does,.. but if you do the same to the summerhouse page, (category1) the text sits alongside the image box, and i want it to sit beneath
MikeyT
Gotcha. I see what you mean. Have you tried adding a class to the div that's wrapping the h1 and paragraph and { float: left;} the div?
Remove the { clear: left; } property on the id named #clearFloat then added a { float: left; } property to the div wrapping the h1 and paragraph. If you add a class to the h1 and { float: left; } as well, it starts to put the paragraph into position. Getting the paragraph to then cooperate and drop below the h1 is the next challenge.
Just tried it in Web Inspector and I think its starting to work. Sorry if my persistence becomes annoying.
CraigRBeta Tester
getting there
Your persistence is gratefully received!
I removed the clear:left property and added a class to the div around the text.
floating left on its own doesn't quite do it, but setting a width moves it down as required.
only thing is, the paragraph text is cut off unless I also set a div height.
Don't know why that is , but its getting a lot closer.
Cheers
MikeyT
Yes, that paragraph is being finicky! Best of luck finishing it up... glad to lend a hand.
CraigRBeta Tester
cheers, much appreciated
