participants property is not an array
I'm getting this message on only one page, the cart works fine and the cart does exist
see attached image
Any ideas
cheers
see attached image
Any ideas
cheers
You can probably ignore it... Have you tried closing and re-opening the page? Do you have the cart added to the page in an include file? When do you get the error? When you open the page or do you have to click on something?
Thanks Ray, they problem has been there for a while just to busy to contact you.
The cart is an include file
I get the error when I go to type or add something to the page
cheers
Can you attach a zipped copy of the page and the WA_ecart folder. I can try to reproduce the issue and figure out the cause that way.
I know I was quick on the reply before, but unfortunately it is now 8pm the day before Thanksgiving, so I'm going to stop working and we are off on Thurs and Friday... so at this point we'll probably have to look into this for you on Monday.
Have a Happy Thanksgiving
I wasn't able to reproduce the error, but I did see there is some missing code for the eCart on that page that could be causing the issue.
Try adding this code:
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
to line 350 just above the <!DOCTYPE>
Thanks Ray the problem seems fixed now
I had this code on line 337
<?php if ($eCart1->redirStr != ""){header("Location: ".$eCart1->redirStr);}?>
removed the code and placed with your code - all fine
Best regards
Norman
