Some basic info please
Thread began 11/21/2012 6:23 am by sam441874 | Last modified 11/22/2012 12:20 pm by sam441874 | 1304 views | 4 replies |
sam441874
Please bear with me as there will be a few stages
1st Stage
Having just got the hang of dreamweaver i purchased Data Bridge. I have set up the registration system which is working perfectly and populating the mysql database. I have now created a form for new users to complete simple sports training tests, enter their scores and press submit.
After 'submit' I want them to be able to go to a page that 'echos' their results and gives them links to other pages for suggested training programs (already in a mysql database) to improve the weaknesses highlighted in the test reults.
Can this be done?
Yes this can be done. The id of the newly inserted record will be saved in the session so you can create a recordset on the page and filter it with that session variable in order to display the newly inserted results and add whatever links you want.
If you use Data Bridge to create the insert and details page the insert will automatically go to the newly inserted record.
sam441874
basic info
Hi ray Thanks for that. I do understand the principle but I bought Data Bridge to eliminate any hand coding. Is there a tutorial anywhere giving me step by step instructions to do this? If not are there any PHP coders who could work professionally with me on this?
Thanking you in anticipation
This doesn't require hand coding... just following the steps and applying the correct server behaviors.
We sell tools, so the user still has to use them to get things accomplished. It's like you bought a jigsaw and someone told you to make an angle cut and you replied "I bought this jigsaw to eliminate the need for cutting wood by hand". Tools don't do anything without the user going through the correct motions. Our tools will help you do exactly what you want and you don't need hand coding, but you still need to do it.
This is something we could walk you through in a premiere support ticket and explain the concepts, show you how to do it, and get it done for you all at once.
sam441874
Ok I'll book one
