navigating to multiple addresses..
Thread begun 11/21/2012 2:29 am by CraigR | Last modified 11/26/2012 8:32 am by Ray Borduin | 6931 views | 16 replies |
CraigRBeta Tester
my google map is retrieving several addresses from a database, and is providing me with 2 issues...
1. The infowindow displays on page load
if i revisit the wizard to edit the settings, the default address is always checked, eben if I uncheck it. - is there a way to manually edit this ?
I tried setting driving directions with no details, but it makes no difference, the infowindow is always displayed
2. I added a form so the user can submit a postcode to get directions, but the directions are always to the same address. How do I update the destination ?
Please provide a url to the page you are working on and I'll take a look and advise on how it can be updated.
CraigRBeta Tester
wheretobuy.php
I will remove the login security for you.
thanks
I had to do a bit of coding to get this working. First I added a function to the page:
function addDirections(fromAddress,toAddress,isDefault,map,icon,point) {
var marker = new google.maps.Marker({
position: point,
shadow: icon.shadow,
icon: icon.image,
shape: icon.shape,
title: toAddress
if (fromAddress && isDefault) {
var directionsDisplay = new google.maps.DirectionsRenderer({suppressMarkers: true});
directionsDisplay.setMap(map);
directionsDisplay.setPanel(document.getElementById("wagmp_directions_3"));
var request = {
origin: fromAddress,
destination: toAddress,
travelMode: google.maps.TravelMode.DRIVING
directionsService = new google.maps.DirectionsService();
directionsService.route(request, function(result, status) {
if (status == google.maps.DirectionsStatus.OK) {
directionsDisplay.setDirections(result);
fromicon = {
image: new google.maps.MarkerImage('plugins/webassist/google_javascript/images/icon_greenA.png', new google.maps.Size(34,35), new google.maps.Point(0,0), new google.maps.Point(9,33)),
shadow: new google.maps.MarkerImage('plugins/webassist/google_javascript/images/traditionalflat_shadow.png', new google.maps.Size(34,35), new google.maps.Point(0,0), new google.maps.Point(9,33)),
shape: {
coord: [1, 1, 1, 20, 18, 20, 18 , 1],
type: 'poly'
marker.setIcon(new google.maps.MarkerImage('plugins/webassist/google_javascript/images/icon_greenB.png', new google.maps.Size(34,35), new google.maps.Point(0,0), new google.maps.Point(9,33)));
marker.setShadow(new google.maps.MarkerImage('plugins/webassist/google_javascript/images/traditionalflat_shadow.png', new google.maps.Size(34,35), new google.maps.Point(0,0), new google.maps.Point(9,33)));
var leg = result.routes[ 0 ].legs[ 0 ];
var frommarker = new google.maps.Marker({
position: leg.start_location,
title: fromAddress,
shadow: fromicon.shadow,
icon: fromicon.image,
var frominfowindow = new google.maps.InfoWindow({
content: ('<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong>From:</strong><br />' + fromAddress.substring(0,fromAddress.indexOf(",")) + "<br />" + fromAddress.substring(fromAddress.indexOf(",")+1,fromAddress.lastIndexOf(",")) + "<br />" + fromAddress.substring(fromAddress.lastIndexOf(",")+1) + "</span>").replace("'", "\\'")
google.maps.event.addListener(frommarker, 'click', function() {
frominfowindow.open(map,frommarker);
frommarker.setMap(map);
then I went into the google map code and updated the infowindowtext field for each of the map points:
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'", "\'", "<strong>Get Directions From Postal Code:</strong><form onsubmit='return false'><input type='text' name='from' value=''/><input type='button' value='get directions' onclick='addDirections(this.form.elements[0].value, wagmp_map_1_obj.addresses[0].full,true,wagmp_map_3_obj.obj,wagmp_map_1_obj.icons[0],wagmp_map_1_obj.points[0]);'  /></form><strong>Address:</strong><br />353 lado de loma<br />vista, ca 92083 US"); ?></span>',
the part that I actually added is:
Which adds the get directions option directly into the info window itself... that way each point can have its own get directions option. You would get rid of the get directions form you have on top of the page since this is a different technique to allow for different directions for the different points.
You would replace the [0] with [1] for the second info window each time it appears.
Let me know if that works for you.
If you don't want any info windows open by default you can comment out the line:
infowindow.open(map,marker);
like:
//infowindow.open(map,marker);
CraigRBeta Tester
thanks for the amazing response Ray.
I got rid of the infowindow - no problems.
I tried adding the function and additional code block to both the map page and the wagmp_map_1.php page, as I was having trouble getting it to work.
i changed references from wagmp_map_3_obj to wagmp_map_1_obj in the code, so it corresponded to my form
the infowindow now displays the search box, but clicking the button has unusual effect.
i get a response from the onclick, i get alert of 0, then 1, then the directions are created, but not to the address i selected, always the ip14 address
can you please clarify..." You would replace the [0] with [1] for the second info window each time it appears."
i think its nearly there, i'm just not quite up to speed.
(I updated my web page if that helps)
thanks
I updated the function to remove the "0" and "1" alerts that I left behind from my testing.
In the second info window it should be:
<form onsubmit="return false"><input type="text" value="" name="from"><input type="button" onclick="addDirections(this.form.elements[0].value, wagmp_map_1_obj.addresses[1].full,true,wagmp_map_1_obj.obj,wagmp_map_1_obj.icons[1],wagmp_map_1_obj.points[1]);" value="get directions"></form>
Notice I updated all of the references of "[0]" to "[1]"
CraigRBeta Tester
sorry Ray, still not getting it.
I found the alerts in the function and removed them.
If I replace the [0] with [1] in the infowindowtext, the submit button doesn't do anything.
I'll admit my javascript knowledge is fairly basic, if I knew what I was trying to do I might get somewhere.
I updated the site, but left the [0] intact for now
Thanks for your help
OK there are a couple of things I overlooked.
First is that the first [0] should not be updated... since that is referring to the form element and not the address.
Second, it appears you are mapping the first point three times. Maybe it is repeated in a recordset or something, but for some reason it is appearing three times in the code. Since that is the case the second button should use this onClick code:
addDirections(this.form.elements[0].value, wagmp_map_1_obj.addresses[3].full,true,wagmp_map_1_obj.obj,wagmp_map_1_obj.icons[3],wagmp_map_1_obj.points[3]);
CraigRBeta Tester
I am still trying to get my head around this.
You are correct in that my recordset had multiple instances of the same postcode, (to try and achieve something else), - so what I have done is created another map page with a simpler recordset, so I only have one row per postcode, in order to get this working, ..I can do the other bit later...
On my map2 page, I presently have 4 address rows returned from my recordset, and 4 map points.
The issue I am having is that the addresses are created on page load - from the recordset, so the form elements are not static.
My recordset is sorted by LocationID, so the order in which the address postcodes are loaded is as follows..
So in the infowindow form, when I change the values in the square brackets as shown, they appear to correspond to the form elements outlined in the table
Postcode LocationID Form Element
IP14 4PH 1 0
CO7 7HH 2 1
CO6 BQT 3 2
IP28 6TX 4 3
<input type='text' name='from' value=''/><input type='button' value='get directions' onclick='addDirections(this.form.elements[0].value, wagmp_map_2_obj.addresses[0].full,true,wagmp_map_2_obj.obj,wagmp_map_2_obj.icons[0],wagmp_map_2_obj.points[0]);' /></form>
eg when I change the values to [2], the directions will be from the entered postcode to CO6 BQT
and when I change the values to [3], the directions will be from the entered postcode to IP28 6TX
So do the form elements[0] and [1] etc also need to be created from within the loop index ?
I have tried replacing the numbers with variables, but it doesn&#8217;t work.
I have uploaded map2.php to my test site, map2.php
Since it is dynamic, you would probably have to use a variable reference instead of numbers at all.
Something like:
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo ("<strong>Get Directions From Postal Code:</strong><form onsubmit=\"return false\"><input type=\"text\" name=\"from\" value=\"\"/><input type=\"button\" value=\"get directions\" onclick=\"addDirections(this.form.elements[0].value, wagmp_map_3_obj.addresses['+loopIndex+'].full,true,wagmp_map_3_obj.obj,wagmp_map_3_obj.icons['+loopIndex+'],wagmp_map_3_obj.points['+loopIndex+']);\"  /></form><strong>Address:</strong><br /><?php echo($Recordset1['street']); ?><br /><?php echo($Recordset1['city']); ?>, <?php echo($Recordset1['state']); ?> <?php echo($Recordset1['zip']); ?> <?php echo($Recordset1['country']); ?>"); ?></span>',
