list features by address ?
Thread began 11/20/2012 12:36 pm by CraigR | Last modified 11/21/2012 2:19 am by CraigR | 1401 views | 2 replies |
CraigRBeta Tester
My client has several sites, each of which has different facilities, and he would like these listed in the info window.
for example...
Site 1
Address
Postcode
Facilities available
• Creche
• Car Park
• Pool
Site 2
Address
Postcode
• Car Park
• ATM
• Showroom
I can set up the data and recordset easily enough, but can’t seem to incorporate this via the interface.
Is this something do-able with this tool ?
the tool doesn't allow you to bind to dynamic data in the Interface, so you would need to compile the code for the info window first using the recordset references, copy the code, then in the Pro Maps interface, past the code into the Custom Info window.
CraigRBeta Tester
Thanks Jason.
It does leave me with a couple of further questions which I will outline is a separate post
If anyone else is interested, here's what I did...
My recordset is based on 2 tables, tbllocation, with the name and address details, and tbllocationfacilities, which has a foreign key locationid and a description of each facility offered.
i then edited wagmp_map_1.php around line 260, so at the start of the do...loop, I build a string to create my facilities list...
// initialize variable to hold previous value
$previous '';
do { ?>
<?php if (($row_rslocations['LocationID']  ."") == $previous ) {
$facilities .= '<li>'.$row_rslocations['LocationFeatureDescription'].'</li>';
} else {
$facilities "";
// set $previous to current value for next time
$previous $row_rslocations['LocationID'];
then just add the $facilities string to the infowindow
