Search Wizard
Thread began 11/19/2012 9:41 am by thehalpeen319342 | Last modified 11/19/2012 1:21 pm by thehalpeen319342 | 334 views | 2 replies |
thehalpeen319342
Search Wizard
Dear Jason, I built a results page that displays the results from two tables using a loop. The page works fine. I want to add a search field on this page. I created one last night using the Wizard, and it worked for me. Unfortunately, I mistakenly dumped the file.
So I tried to recreate the search form this morning using the wizard. However, this time, it does not display the results of the search - all the records are returned. What have I missed this morning- see attached file.
Jason_Search.zip
the code for the rsHse recordset is duplicated.
change lines 75 - 84:
mysql_select_db($database_CommSimpleRegister, $CommSimpleRegister);
$query_rsHse = "SELECT * FROM new_table ORDER BY fullname ASC";
setQueryBuilderSource($query_rsHse,$WADbSearch1,false);
$rsHse = mysql_query($query_rsHse, $CommSimpleRegister) or die(mysql_error());
$row_rsHse = mysql_fetch_assoc($rsHse);
$totalRows_rsHse = mysql_num_rows($rsHse);
thehalpeen319342
Thanks a million - your a genius!! Don't know how i did that, but I'll be aware the next time.
