Form Validation Show If NOT WORKING
the SHOW IF server validation dont work right!
It destroys my CODE, puts in the code where it wants!!!
Or doesnt it work with SPAN?
Denis
Denis
It will work with a span tag, but you should make sure to use the Tag Selector to select the area that the show if should be applied to. Highlight the text in design view, then go to the tag selector and select the tag that the error text is in.
