Add to Cart Not Working
Thread began 11/18/2012 5:37 am by sfranzken73972 | Last modified 11/20/2012 6:20 pm by sfranzken73972 | 820 views | 8 replies |
sfranzken73972
Can you please tell me why my add to cart, quantity and button are not working?
menu.php
cartIssue.zip
This issue is caused by the way the nested repeat region plugin you are using works.
the recordset used by the add cart button, and also by the nested repeat creates an intial empty data set on page load.
to correct this, edit line 46:
$query_detail2menu = "SELECT * FROM menu WHERE cid=123456789 ORDER BY itemname";
$query_detail2menu = "SELECT * FROM menu ORDER BY itemname";
then change line 126:
$nested_query_detail2menu = str_replace("123456789", $row_master1menucategories['id'], $query_detail2menu);
sfranzken73972
Only Showing From 1 Category Now
Hi Jason and thank you for your help.
I updated the code as per your suggestion, however now it only shows 1 category and its items.
menu.php
add the following code at line 1:
error_reporting
(E_ALL);
and send a copy of the updated page.
sfranzken73972
Ok I did Jason
menu.php
i still need a copy of the updated page.
NOTE: you are getting a Headers already sent error message at line 5, this is most likely caused by a blank space or line after the closing ?> tag in the error reporting code:
make sure there is no blank space or line after the closing php tag.
sfranzken73972
Sure thanks and here you are
Here you go Jason checking that issue now and thank you!
menu.zip
in addition to making the changes i had suggested, there was also code removed from the original page that i did not suggest.
in the original page the was a do staement to start the lop for the main recordset at line 120. line 120 - 123 was:
<?php do { ?>
<tr>
<td colspan="3" class="bold"><h1><b><?php echo $row_master1menucategories['category']; ?></b></h1></td>
</tr>
and lines 157 - 158 where to while statement:
<?php } while ($row_master1menucategories = mysql_fetch_assoc($master1menucategories)); ?>
</table>
those 2 have been removed which removes the loop for the main recordset.
i suggest downloading the original attachment you sent me, then only making the changes that i suggested in my initial replay, leaving the main recordset loop in tact.
sfranzken73972
Thank you Jason it worked!
