Error after install, can't use Universal email
Using CS6, after install I select Universal Email and I get the following error:
(View attachment).
Already uninstalled and installed again with no luck. Please advice what to do.
A
(View attachment).
A
Universal Email is not compatible with Dreamweaver CS 6, it was replaced with Form Builder, then compiled into Data Bridge.
you will need to continue using your previous version of Dreamweaver to use Universal Email, or purchase an Upgrade to Data Bridge in order to use it in DW CS6.
