My Level 2 on Menu disappearing on hover
Thread began 11/17/2012 7:00 am by donald.dickson338135 | Last modified 11/18/2012 2:52 am by CraigR | 562 views | 1 replies |
Would appreciate some guidence on how to put right my current challenge on a work-in-progress development. Thanks - Don
System Windows 64bit Dreamweaver CS4 MenuWriter 2.05 SiteSculptor version 1.0.0
Problem Statement:
Horizontal CSS Menu constructed with Main, Level 1 and Level 2
Main and Level 1 work as expected.
In browser the level 2 menu displays but disappears before an item in the Level 2 menu can be selected.
Holding down the left mouse button for an item in level 1 (with a level 2 sub menu) and dragging the mouse to level 2 has these effects.
(1) in IE9 the cursor shape changes but permits selection of level 2, i.e. the level 2 menu stays on screen
(2) in Firefox 16.0.2 the cursor shape changes but the level 1 subject menu item is dragged across to the level 2 sub menu and then permits selection of a level 2 item
The secondary issue is the large screen space between the level 1 and level 2 menu
If making visual check the Level 2 menu displays are on the menu tabs 'Events' and 'History'
Visual check at co5ogsx
Action taken
(A) Cross Browser compatibility Set all Margins to zero (note that despite this I still have a line of code in cssmw_home/menu.css with the following line <<margin: 0 1px 0 0;>> see code snippet from cssmw_home/menu.css below)
(B) checked Forum and located similar issue with the solution <<in the CSSMenuWriter/cssmw/menu.css file, edit the ul#cssmw li selector and add: width: 150px;>> (Issue, my version of CSSMenuWriter does not have the folder cssmw)
Situation
Folders in my CSSMenuWriter/
cssmw_home_images
cssmw_home
Cssmw_content_images
cssmw_content
cssmw_home contains menu_ie.css and menu.css
cssmw_content contains menu_ie.css and menu.css
Code Extract from cssmw_home/menu.css
line 99
ul#cssmw_home ul.level-1 > li > a, ul#cssmw_home ul.level-1 > li > a:link {
background-color: #FFFFFF;
background-image: none;
color: #000000;
display: block;
font-family: Arial, Helvetica, sans-serif;
font-size: 12px;
font-style: normal;
font-weight: normal;
height: 20px;
line-height: 20px;
margin: 0 1px 0 0;
padding: 3px 5px 3px 10px;
text-align: left;
text-decoration: none;
text-transform: none;
width: 100px;
outline-style: none;
Code Extract from cssmw_content/menu.css
line 169
ul#cssmw_content ul.level-2 > li > a, ul#cssmw_content ul.level-2 > li > a:link {
color: #000000;
display: block;
font-size: 12px;
font-style: normal;
height: 20px;
line-height: 20px;
padding: 3px 5px 3px 5px;
text-align: left;
width: 100px;
CraigRBeta Tester
the large space between the level 1 and level 2 menus is because of line 163 in menu.css
ul#cssmw_content ul.level-2 {
left: 149px;
the width of the level 1 element is 100px.
try changing the width of either, (increasing the width of the parent, or reducing the left offset above, so the child elements are offset by the width of the parent)
