Coupon Code Tutorial
Thread began 11/13/2012 2:15 pm by johna1964 | Last modified 11/14/2012 12:17 pm by johna1964 | 2223 views | 10 replies |
johna1964
Is the archived Coupon Code tutorial is still usable for all versions of eCart?
Thank you,
johna1964
Yes, the concept is still the same in newer versions of eCart, the only difference is the interface.
johna1964
Thank you!
johna1964
hi,
should the coupon form be created inside or outside of the cart form?
I have followed the tutorial, but to no avail, so i uploaded the cart file.
My apology for things not going smoothly for me, but just know i truly appreciate you help
thank you,
johna1964
cart_w_promo.zip
outside the cart form.
johna1964
Okay, thank you.
I have the coupon form where i need it, it is not working.
When is it suppose to apply the discount? The discount isn't showing at all. The only deviation from the tutorial was the coupon code:
WebAssist is now HappyVaping.
When do they hit the submit button for the discount to apply? Either way it doesn't seem to work. So I'm doing something wrong again...
The coupon form is on line 390-394.
cart_w_promo-1.zip
the coupon form looks right.
the set session value behavior is in place.
are you clicking the submit button after entering the coupon code?
how is the discount configured. send a screen shot of the discount window showing the settings
johna1964
hi,
i'm pressing the button after entering the code.
Here is the sceenshot
screen_shot.zip
in the rule you are using the session variable:
Promocode
but the name should be:
PromoCode
capitol C
php is case sensitive.
johna1964
Wow - thank you for pointing that out...
another lesson learned.
Thank you!
johna1964
P.S. Made the change - it's working like a champ. :-)
