Form
Thread began 11/13/2012 8:37 am by sjuno299871 | Last modified 1/14/2013 10:55 am by Jason Byrnes | 3414 views | 25 replies |
sjuno299871
Form
I added a check box to my form (data Bridge) with check boxes yes and no how do I pass the yes or no value to the email? I am going to add to a database but one thing at a time ....
Right now it just shows Array
"Name: "Hello Juno "Email Address: "sjuno1@new.rr.com "Comments: "Test "Mailing List:"Array
this is because the checkboxes are set to allow multiple selection.
add the following code at line 1 of your form page:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", "$_POST[$key]);
sjuno299871
I want to add this check box to my user's table how do I do this? values?
in the insert record behavior, bind the column to the checkbox form element.
sjuno299871
Ok still not getting the yes or no response to email
formphp.pdf
your form posts to the results.php page, the code i suggested should go at line 1 of the results.php page
sjuno299871
Ok Jason all I want to do is to have a form to have them enter name, email, comments and a yes or no to a question,if they want a newsletter. Then I want an email sent(understand the email part) and store it in a table in the database. Just used the results page following the form tutorial have since changed the page acion to itself (form page)again everything came thru but the Newsletter info....my guess is I am not passing a Yes or No?
EmailRec.pdf
formphpcode.pdf
in the universal Email behavior how are you setting up the body?
using the "Crate a File To manage the email body" option?
This is the easiest way to configure the email body, i recommend using this option.
or using the Dreamweaver edit option?
If using this option, make sure you are adding the binding for the News letter form element
sjuno299871
I am using the email function in the Form Builder...using the Create a simple contact form, and email the contact information tutorial...
that does not answer the question that was asked.
in the Universal Email server behavior, how are you configuring the body of the message?
have you selected the option to "Crate a File To manage the email body"?
