property error
Thread begun 11/12/2012 2:25 pm by Patrice | Last modified 11/19/2012 9:55 am by Patrice | 4161 views | 9 replies |
PatriceWebAssist
property error
Google search tool
Notice: Trying to get property of non-object in /var/www/html/webassist/google/search/plugins/searchbase_custom_search_3.php on line 22
Notice: Trying to get property of non-object in /var/www/html/webassist/google/search/plugins/searchbase_custom_search_3.php on line 37
I've never tried to use Google search tool so it's probably something stupid I'm doing. I've redone page several times, once with a result but not a form button, so redid and then it failed.
test page:
searchbase.php
try shoes or jackets
I am not seeing an error on testing your page. seethe attached screen shot.
PatriceWebAssist
Thanks Jason. It is working today. Gremlins.
PatriceWebAssist
Hmmm... testing for opening in new window:
searchbase2.php
getting
Notice: Trying to get property of non-object in /var/www/html/searchresult.php on line 24
Notice: Trying to get property of non-object in /var/www/html/searchresult.php on line 39
weird...
can you send the searchresult.php page so i can take a look at the code.
PatriceWebAssist
Attached...thanks so much.
PatriceWebAssist
Sharing the solution in case it helps someone else.
This is an issue with having "register_globals" turned on in your php.ini
the search object is named "WAGS_custom_search"
and it saves a session variable "WAGS_custom_search"
and with that setting turned on they overwrite each other
I updated the include file to use a different session variable name
This should be corrected in the next update to free tools.
I looked at files and saw a date change on webassist>google>search>object>wa_google_search.php so I am guessing that is the changed file.
And then another question. These were just test pages, and now I need to incorporate into site and replace an older search system. Will the error work itself back in upon recreating a new search set? I do know how to turn off globals in php.ini. Would that change hurt any other php systems on this huge site? Good idea, bad idea?
Thanks again, Jason.
here is and updated copy of the webassist/google/search/object/wa_google_search.php file to correct the problem.
you can use this file in other sites that you create to prevent the problem in the future, it will be corrected in the next update as well.
PatriceWebAssist
Thank you!
