Page from Template - where has it gone?
Thread began 11/12/2012 10:33 am by Daryl | Last modified 11/12/2012 12:17 pm by Jason Byrnes | 653 views | 2 replies |
DarylBeta Tester
I havent used the Data Assist within Databridge for a while.
How do you have the for created in a template page like you used too?
DarylBeta Tester
Ive read some other threads on this and have now changed a page to a dwt and then have made it into a theme.
If I create a Data Assist page first and then try to apply the theme, I get "You must have a dreamweaver template applied to your page to use Framework Themes."
However if I create a new page from theme it works OK.
The thing I dont understand is, if I create a page from a dwt or theme, how do I then add a data assist insert form? Do I then have to add it as a plugin?
Is there a way to add a theme to a data assist page?
the Template or theme needs to be applied after running the wizard.
to apply the template, open the page and go to Modify -> Templates -> Apply Template to page.
the template needs to be applied to the page before the theme can be applied.
