Datepicker show if
Thread began 11/10/2012 12:03 pm by jo271221 | Last modified 11/12/2012 8:03 am by Jason Byrnes | 922 views | 1 replies |
jo271221
Datepicker show if
1. When I update the enddate it shows 2012/12/12 format and is suppose to be 2012-12-12 as eventdate is. I don't know if that is causing the end date to display when it is the same as the start date or if I have an issue with the start date. Regardless the end date should display by default matching the format of the start date.
2. When the events display on the page they should display Sat November 10, 2012 to Sat November 10, 2012
which is correct, however the end date is only suppose to display if it is NOT the same as the start and AND if it is not null or empty. I don't have the and if not null or empty coded yet on the end date but I believe I have that correct at the start date.
_p_updateAndDetail.zip
1) I dont follow. Where is it showing the date in the incorrect format? on the details page? results page? please provide more details and a screen shot.
2) On the details your if statement is using 2 separate date formats:
<?php if (date('D F j, Y',strtotime($row_WADAtbl_post["eventdate"])) != date('D n/j/Y',strtotime($row_WADAbrevents['enddate'])) && $row_WADAtbl_post["eventdate"] !='' ) { ?>
you are using D F j, Y for eventdate and D n/j/Y for enddate. in reality, you should just be using the timestamp generated by the strtotime command:
<?php if ((strtotime($row_WADAtbl_post["eventdate"]) != strtotime($row_WADAbrevents['enddate'])) && $row_WADAtbl_post["eventdate"] !='' ) { ?>
