dates not showing properly..
Thread began 11/09/2012 3:53 am by JamieEff | Last modified 11/12/2012 1:28 am by JamieEff | 1345 views | 4 replies |
JamieEff
Not sure what I have done wrong here but on this page - blog.php - the right hand column dates arent showing correctly (the bottom one should show as 05 Nov 2012.
And, imagine this is linked to the above, when you click on the link and go to the relevant article then the date for that article is posted on both of them...
Have attached the page
Thanks in advance
Jamie
blog.zip
in the BlogRS recordset, edit the select list to return the posted date:
SELECT C2.ContentDate, C2.ContentGroup, C2.ContentPageSetOrder......
then in the left hand side, use the BlogRS.ContentDate to display the date:
include('WA_CMS/addtosite.php');
echo(date("d M Y",strtotime($row_BlogRS['ContentDate'])));
JamieEff
Hey Jason
Its not the left hand side that is misbehaving... its the dates in the blue boxes on the right hand column....
Jamie
sorry, i got the side wrong, but that doesn't change the answer.
update the BlogRS recordset,
then use the BlogRS.ContentDate column to display it in the repeat region.
JamieEff
brilliant... thanks Jason.
Hope you had a good weekend!
