Value not in session
When I login to Admin the UserID, UserGroupID are not being set in session. Even when I try to set them, they are not showing up when I put in
<?php echo $_SESSION['UserGroupID']; ?>.
i dont see in either of the pages that you sent where you are trying to echo the session variable.
sometimes you have to force PHP to find the session. On a page that you are trying to echo session variables, you should include the following code:
<?php @session_start(); ?>
What I'm trying to do is when you try to access the admin section, the admin menu is always visible even when you not log in. See link below.
admin
I created an Access Rule and Access Group and apply it menu.php but it's not working because the groupID is not in session even though I try adding it. See attachment.
I'm trying to make the menu visible only when you login to the admin section.
I see, so your trying to use the session in an access group.
When setting u access groups, it's easy to add a blank value. make sure there is not a blank member of the access group.
try click bellow the 7 in the list of groups, if you can select a row bellow the 7, there is a blank member to the group that needs to be removed.
I just realized that it wasn't working only for the Super User because it was in kfm_users table and not the users table so I went and added <?php echo $_SESSION['AdminLogin']; ?> to my rules access and it works.
One thing I'm trying to wonder when I click and close a window my session don't get cleared and you are still login, shouldn't it clear the session and the individual logout?
no closing a browser window wont end the session, you would need to close the browse completely to end the session, or go to the logout page.
