Form doesn't send
Thread began 11/08/2012 12:06 pm by Kamen Nikolov | Last modified 11/08/2012 2:50 pm by Jason Byrnes | 568 views | 5 replies |
Kamen Nikolov
Form doesn't send
Hello,
I have used the CSS Form Builder and created a Contact Us form (htt://www.sharigeller.ca/temp/contact2.php), The form doesn't send and it doesn't Go to the page I wanted after pressing the submit button.
Any help will be appreciated. This suppose to be easy.
Thank you.
send a copy of the contact2.php page please.
Kamen Nikolov
Here it is.
contact2.php.zip
the code looks correct. when I test your page, it looks like validation is failing, but it is not remembering the validated entries, this looks to me like a problem on the server with saving sessions.
use the sessionTest.php script from the following thread to test the servers session management abilities:
showpost.php?p=23826&postcount=2
if the session test fails, it is mot likely a bad session.save_path setting in the php.ini file, you will need to contact the host to have them fix the problem.
Kamen Nikolov
Session variables Problem. Got it.
Thank you Jason.
Kamen
you're welcome.
