Image upload question
Hi Jason,
When using the file upload and it is set as web images I want the resize option to size the image to be at MAX 600 pixels on the longest side WITHOUT adding any fill color.
So I use:
Fixed width and height - will resize all images to a specified width and height while maintaining the width-to-height ratio. If the resized image does not completely match the specified width and height, a fill color is applied.
and I do not select a fill color so it will therefore not add any color and the image will retain the WxH ratio.
Is that correct?
thx
Eric
