Old DFP1 New Instructions
Yeah I have not been able to afford the new Data Bridge...yet (after I get paid from this site I am getting it)
Actually it is DFP2 that came with CssFormBuilder.
I am stuck using old DFP2 and following instructions for adding image upload to a DataAssist 2.1 page.
I have made it thru all except the last:
I am on the Update page -
Updating the Update Record server behavior
We now need to update the DataAssist Update record server behavior to accommodate the file field.
20.From the Server Behaviors panel, double-click on the Update Record option. DONE
21.Click Next to proceed to step 2. DONE
22.Select the column you applied the file field to. DONE
23.Click the value lightning bolt. DONE
24.Expand the WA Upload File option for your column. DONE
25.Choose Server File Name.
There is no "Server File Name" option .
There is a Field Name, Temp Path, Simple File Name, Extension, Mime Type, File Size, Image Width, Image Height, Error.
Which one should I select?
On the Insert instructions there was a Server File.
