Email is not sending
Thread began 11/06/2012 5:10 pm by sandy170299 | Last modified 11/07/2012 11:40 am by Jason Byrnes | 1400 views | 5 replies |
sandy170299
I think I have everything in the right order, meaning that the query that the email is being sent from comes before the send email code, but it's just not sending the email. I am not receiving any errors - it goes through the whole process, it supposedly sends an email, and then updates the database with an update query after the email is sent. The email address that the email is being sent to is pulled from a query that uses a session variable. I have confirmed that the session variable for employeeID is in fact working and the query is running correctly. I am attaching the page. Thank you.
qryCommit.zip
Both the update and the email use form post data, but i don't see a form on this page?
Is the form on another page?
the update is set to redirect to the employeeJobs_results.php page, does that redirect happen?
who is your host?
in Universal Email, what have you set as the SMTP Server? SMTP Port? From Address?
Is the From Address a valid address for your domain?
double check that there are no errors occurring, add the following code at line 1 of the page to turn on error reporting:
error_reporting
(E_ALL);
when the email sends, it will set session variables that contain the status of the email. on the employeeJobs_results.php page, add the following code to write the sessions to the page for information:
<pre><?pre var_dump($_SESSION); ?></pre>
sandy170299
Is the form on another page? Yes - it redirects to the page that sends the email.
the update is set to redirect to the employeeJobs_results.php page, does that redirect happen? Yes, it does redirect correctly.
in Universal Email, what have you set as the SMTP Server? SMTP Port? From Address? Nothing - I don't need to add any settings.
in Universal Email, what have you set as the SMTP Server? SMTP Port? From Address? Actually, no it's not, but I'm not sure if that is the issue or not. I will check.
PHP Code:
error_reporting(E_ALL);
I added the code, but I'm not sure what all of the errors mean now. This is all I'm getting: Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/qryCommit.php on line 131
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/qryCommit.php on line 131
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/qryCommit.php on line 161
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/qryCommit.php on line 161
Warning: Cannot modify header information - headers already sent by (output started at /home/citstime/domains/citstime.com/public_html/qryCommit.php:5) in /home/citstime/domains/citstime.com/public_html/qryCommit.php on line 192
the error is probably a blank space or blank line after the closing php tag of the error reporting code.
see the following thread for details:
showthread.php?t=19285
you did not mention who the host was?
Most hosts require that the From Address be a valid email address for the domain or they wont relay the message.
did you add the session dump code to the success page?
The session dump will help us determine if the email is getting to the SMTP server or not.
sandy170299
Yup ... I did it again. There was ONE SPACE after the closing PHP tag. Okay ... here is the problem. I need to reference a query in the following:
$MailBody = $MailBody . (GetFromPage("templates/Blank_3.php"));
Question ... how do I get the contents to show up when they are being passed from a form variable? Do I need to make all of those form variables a session variable?
This is part of what is being returned on employeeJobs_results.php. It's losing the form values, I believe.
Your Email Title Goes Here
email subtitle area or directions can go here, below the title
Form Submitted: 11-7-2012 | 1:22 PM CST
startDate: 10/01/2012
endDate: 11/07/2012
submit: Click to Commit the Following Hours
Additional Notes:
labor code id job id date worked hours worked
Notice: Undefined variable: row_getData in
/home/citstime/domains/citstime.com/public_html/webassist/email/templates/Blank_3.php
on line 66
on line 67
on line 68
on line 69
Notice: Undefined variable: getData in
on line 71
Warning: mysql_fetch_assoc() expects parameter 1 to be resource, null
given in
on line 71
Notice: Undefined variable: getEmployee in
on line 83
Warning: mysql_free_result() expects parameter 1 to be resource, null
given in
on line 83
