Text Validation
Thread began 11/06/2012 12:29 pm by halclark410864 | Last modified 11/06/2012 2:13 pm by halclark410864 | 740 views | 2 replies |
halclark410864
Text Validation
I am having problems when I try to validate a text field. With no text fields validated and when no fields are left blank the form will submit just fine. When I try to validate the name field and even when text is inserted in the name field and not left blank, you can not submit. The link to the form is:
jbrform.php
The source code is here:
ali.txt
Hal...
your form elements use invalid names.
you cannot use spaces in the form element names:
<input id="Name One" name="Name One" type="text" value="" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Name One_ServerError');">
halclark410864
Validation
Thanks Jason I knew it was something simple. Works great now.
