transferring one database to another....
Thread began 11/05/2012 11:53 am by JamieEff | Last modified 11/06/2012 3:38 pm by Jason Byrnes | 591 views | 3 replies |
JamieEff
Hi guys
I recently had to migrate a site which had a small database (see attached file) on it and put it into a PCMS configuration.
I did this manually which was fine as it was not a huge amount of data, but just for my future reference how would I transfer that into the PCMS database?
cheers
Jamie
old_blog_data.zip
you would need to use PHPMyAdmin to export the database then import it.
JamieEff
Hey Jason
I understand that, but hat I meant was the migration of the data itself from one database to a completely different one which uses different tables etc....
Jamie
after exporting the database, you would need to edit the SQL file to map the inserts to the column names for the table you will import to.
