ecart replace product
Thread began 11/05/2012 11:38 am by bchilds | Last modified 11/05/2012 3:51 pm by bchilds | 395 views | 2 replies |
bchilds
I am building a quick ecart where you can only have one product in the cart. If you select a different product it should replace the first product. There are only four products available.
Unfortunately I just cant get it to work even though I select replace in the add to cart object.
Help would be appreciated... Files attached. ecart 4.5.1
Bchilds
ecom.zip
the option to replace the product if it is already in the cart uses the product ID to determine if it has been added to the cart already or not.
for the replace option to function, the product ID for each product would need to be the same.
bchilds
Brilliant thanks!
