Redirecting to same page with custom text
Thread began 8/07/2009 1:28 pm by rbudj | Last modified 8/07/2009 6:03 pm by Jason Byrnes | 1147 views | 2 replies |
atstech
Using SA1.7.7 on Windows 7 - Dreamweaver CS4 and PHP
So I ran the SA wizard. In the setup process, on the user registration page, I choose to redirect to the same page (user_Registration.php) if the Email Address was found in the database. So my idea is if the email address already exists in the database, redirect to user_Registration.php and display red text, "That email address is already registered"
I cannot for the life of me figure this out. I know I have to have an IF statement, but on what condition? Here is what I have been trying:
if($loginFoundUser) {
echo "That email address is already registered";
This is not working. Any other ideas on how I can accomplish this?
atstech
Ok, so i have figured out how to display a message. Basically what I did was in the //append the username to the redirect page section, I added a variable:
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername . "&exists=1";
header ("Location: $MM_dupKeyRedirect");
The variable I added is the &exists=1. I then placed this code:
if (isset($_GET['exists'])) {
$exists = $_GET['exists'];
if ($exists == 1) {
echo "Hello World";
So I will now be able to give the visitor a message with further instruction if they enter an email address that is already in the database.
Now, my next question is very much related. How do I bind the text fields? Right now, if the user is redirected due to the email address, all the data they entered into the form text boxes disappears. I tried binding the form data to the fields with no luck. Do I HAVE to use the URL to pass variables or is their another way? If I can pass the variables to the Header (Location, then I can solve these problems I am having.
You could pass the posted information through the query string.
For each form element add another querysting variable. for example if you have form elements named "email" and "name":
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername . "&exists=1&name=".isset($_POST['name'])?$_POST['name']:""."&email=".isset($_POST['email'])?$_POST['email']:"";
then, on the bindings panel, for each querystring variable you add, click the plus button and select URL Variable and type the name of the variable.
Next, bind the form elements to the URL Variables.
