Automatically adding a product?
Thread began 10/31/2012 7:56 am by josephman1988418631 | Last modified 11/02/2012 7:51 am by Jason Byrnes | 1482 views | 9 replies |
josephman1988418631
Hi Guys,
Basically I want to be able to say, once the user has logged in, automatically ad a specific product to the cart, and send them to the final checkout page.
If possible, the best scenario would be when the user 'registers', they have a 'single membership' product added to the cart, then it goes straight to sagepay.
If anyone can help me with either method that would be fantastic.
Regards,
Joe.
you can use the Add to cart server behavior for this.
the add to cart server behavior can be accessed from the server behaviors panel (Window -> Server Behaviors). click the plus button the select eCart -> Add to Cart.
set the trigger to use the registration button pressed.
after it is added, you will want to make sure the code for the add to cart is added after the code for the Insert record.
josephman1988418631
Thanks for pointing me in the right direction.
How do I change the trigger so it activates on the registrationg submit button rather then the one that the 'add to cart' server behaviour adds?
I guess I'm asking how do i 'alter' the trigger?
The trigger dropdown select list should have options for each of the form buttons on your page.
Select the Registration button pressed option.
josephman1988418631
When I click 'add to cart' I'm prompted with the following 3 tabs which I have attached.
I can't control the trigger for this behavior?
Sorry if I'm being stupid!
This is the Add to cart button behavior, not the add to cart server behavior.
to add the add to cart server behavior, open the server behaviors panel, click the plus button and select eCart -> Add to Cart -> Add to Cart
josephman1988418631
The previous screenshot is what opens when I do your instructions:
New attached image shows the process your explaining and the previous shows the window that opens when clicking this.
Fairly confused!
Thanks for your help so far!
What version of eCart?
The add to cart server behavior was added in eCart 5, if you have a previous version, the trigger will need to be hand coded to accomplish what you are trying to do.
send a copy of the registration page with the add to cart button on it and I can tell you what code to change.
josephman1988418631
No wonder it wasn't making sense! It's v4.5.
Note that the attached file, line 96, is one I tried manually, this can be ignored.
Thanks!
Regards,
Joe.
register.zip
the add to cart button trigger is at line 147:
if (isset($_POST["skincentrics_1_ATC"]) || isset($_POST["skincentrics_1_ATC_x"]))     {
change that to:
if (isset($_POST["KT_Insert1"]) || isset($_POST["KT_Insert1"]))     {
NOTE: you will also need to merge the add to cart form elements into the registration form
change the following code:
<input type="submit" name="KT_Insert1" id="KT_Insert1" value="Register" class="eC_FormButton" style="background-color:#d4a67c;" />
                </div>
                </form>
<!-- Confirm Form -->
<form name="skincentrics_1_ATC_22" method="POST"  action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>">
  <input type="hidden" name="skincentrics_1_ID_Add" value="22" >
  <input type="text" name="skincentrics_1_Quantity_Add" value="1" size="4" >
  <input type="submit" value="Add to Cart" name="skincentrics_1_ATC">
</form>
                </div>
  <!--<input type="submit" value="Add to Cart" name="skincentrics_1_ATC">-->
</form>
