set up database end date for coupon--get white space message in cart
Hello,
I set up the end date for database coupon codes as per instructions here:
showthread.php?t=20313&highlight=coupon+end+date+database
the db is: couponCodes
fields are: couponid auto inc , couponCode varchar, couponAmt double, expDate date
When I test it on testing server I get this msg:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /Applications/MAMP/htdocs/megan_isaacs_cms/WA_eCart/megan_isaacs_PHP.php on line 172
I have looked and looked at this line and cannot see the problem.
Everything worked prior to adding this to the cart discount
Sending files cart.php and the wa php page.
Thank you,
K
