Search Results
Thread began 8/07/2009 11:08 am by mike292921 | Last modified 8/07/2009 7:31 pm by Dani Chankhour | 1460 views | 1 replies |
mike292921
Search Results
I am happy with Dataassist search. I am using advance search that is simply pulling item names and descriptions. Sometimes when I type a keyword in exact to the items name and description it won't show up till later in the search when I would like it to show up first.
Am I doing something wrong or what?
Thanks Again
Mike
Dani Chankhour
You will need to add sorting to your query. In Dreamweaver, open the DataAssist Search query record set and then add a Sort to your query. Or you can add it manually by adding something like this:
ORDER BY name DESC
to the end of the query. (make sure to replace 'name' with the column you want to order by).
