Charging and Recording State and Federal Taxes Separately
Thread began 8/07/2009 7:58 am by Kevin373660 | Last modified 8/07/2009 2:39 pm by Eric Mittman | 1319 views | 1 replies |
Kevin373660
I do not want to duplicate effort, I have asked Eric to reply on this question in ticket #100961, however it others in the forum may benefit from the clarification of this tax portion of my ticket. I have added more specific information below than I had included in my last ticket entry. I will add the reply to this thread for the benefit of others who may find this important and beneficial.
To comply with accounting and government regulations, I need to both charge and record state/provincial and federal taxes amounts separately. Applicable taxes and rates depend on customer location and product. I am using DataAssist, eCart with MySQL and PHP.
My understanding is:
1. From what I have read, eCart uses a state abbreviation variable in conjunction with a sateTaxRate multiplier held in the db “State” table specific to that state. (Example: $WAGLOBAL_TaxState = "NY"; )
2. In examples and documents a combined tax total value “OrderTax” is used. This value is also stored in the “Orders” table.
To facilitate:
If I simply add the extra two fields for “StateTax” and “FederalTax” to my “Orders” table can eCart then identify and place the values for each tax in the table along with the combined “OrderTax” total. I am assuming that the total may be required for payment processing purposes.
Additionally, some products are charged only Federal tax others both State and Federal. Therefore, do I need to add two fields in the “Products” table so that each product’s taxable rate would be recorded? Then apply a rule somehow in eCart to filter and apply?
In order to setup your checkout for state and sales tax you will first need to ensure that you have the two new columns in your orders table.
The idea is that you will use the eCart tax tab to create the tax rules. You will need to define the condition for which these tax rules are applied. For the state tax the idea is that the user selects the state from a select list, you can then use this user selected value for a state specific tax rule, or have a dynamic tax rule for the state.
A state specific tax rule is static, if the user selects a certain state then you will need to have a rule defined for that state that specifies the percentage of tax to charge.
In a dynamic rule you have the states and rates in a table, then when the user selects the state you will filter a recordset based on that value. You then store that rate in a session variable. When you configure the tax rule you will just check to see that your state tax rate session variable is set, and if it is then charge a percentage referencing this state rate session variable. This way you can have a single state tax rule for all the states.
When you are storing the order details you would use the bindings for your tax rules for their respective columns, then record the order tax using the regular eCart tax binding, this is a total of the tax rules applied.
As for adding the tax rates to the products this may enable you to control the federal tax as a per item calculation, then when you create the federal tax rule you can just use the total of your applied tax calculation as your federal tax amount for the order. If any part of this is not clear or you need any further info post back with some specifics and we will be glad to help.
