Change time format
Thread began 10/26/2012 8:19 am by colinlangley441259 | Last modified 11/01/2012 1:37 pm by Jason Byrnes | 1877 views | 7 replies |
colinlangley441259
Change time format
Is there any way to change the time format from 00:00:00 to 00:00 please?
The code i have is:
<?php echo $row_Recordset1['from']; ?>
so the from column is storing the Time only? as hour:minutes:seconds? for example:
13:41:32
use the following which will convert the time to a full date, and use the date function to convert it to Hours:minutes
<?php echo(date("H:i"strtotime("2012-1-1 ".$row_Recordset1['from']))); ?>
SPT
Hi Jason,
I am trying to accomplish the same thing but different. :)
I wanted to show the month day, year and strip the time.
Original line is:
<?php echo($row_WADAblog['updated']); ?>
I have tried:
<?php echo(date("M d, Y", strtotime("00:00:00 ".$row_WADAblog['updated']))); ?>
But it displays Dec 31, 1969 for all.
I also tried the SQL DATE_FORMAT(updated "%M %d, %Y') AS updated
Maybe that was the wrong approach.
But get sql error.
what is the original value of $row_WADAblog['updated']?
you can probably just us this code:
<?php echo(date("M d, Y"strtotime($row_WADAblog['updated']))); ?>
the reason for adding a date to the code for the OP in this thread was that they had the time stored in the database as hh:ii:ss (ex. 12:41:22)and the wanted to strip the seconds(ex. 12:41). the strtotime command requires a full date (yyyy-mm-dd hh:ii:ss), so for the date command to work, a date needed to be added to the time (ex. "2012-1-1 ".$row_Recordset1['from']).
in your code, your adding time information to the date at the beginning which not the correct format.
SPT
Original line is:
Your line worked great!! Thanks again!
that wasn't the question.
the question was what the result of the original code was.
did you try using:
as I suggested?
SPT
did you try using:
PHP Code:
<?php echo(date("M d, Y", strtotime($row_WADAblog['updated']))); ?>
as I suggested?
Yes sir - and your code worked great. Just what I needed. Thanks
OK, glad to hear it is working.
