Dynamic Sales Tax Rate
Thread began 10/25/2012 9:56 am by Armen | Last modified 10/25/2012 2:52 pm by Armen | 1127 views | 2 replies |
Armen
I am using eCart 5.06 on DW 5.5 PHP/MySQL
I currently have an eCart Merchandising Rule that calculates the sales tax based on a static number I entered within the Merchandising Rule. How can I pull the tax rate from a database? I have a table that contains the rate (8.75) how do I replace the current static figure with a reference to the database field?
you would need a recordset that returns the value from the database, then use the Set Session Value behavior (Click the plus button on the Server Behaviors panel and select eCart -> General -> Set Session Value) to store the tax rate in a session variable.
in your tax rule, set the Flat rate tax to use:
$_SESSION['sessionName']
where sessionName is the name of the session variable.
Armen
Thanks Jason!
